stupid question part 1: front brake bleeding.
Posted: Thu Apr 08, 2010 9:17 am
by ibby4585
Right ive got my front sp1 brake set up on my bike, with new pads etc. I want to start to bleed the system from dry. Im going to use a non return valve and a syringe because ive heard its a bit of a nitemare drawing the fluid to the calipers.
silly questions.
is it best to draw the syringe from the caliper or inject it into the line from the resevoir?
also do i bleed the fronts one side at a time? or both together? as you can tell ive not done this before!!
any help guys would be great!!
Kris
Re: stupid question part 1: front brake bleeding.
Posted: Thu Apr 08, 2010 9:23 am
by mattUKNC
I haven't used the syringe method, but I'm guessing you'd pull it through from the caliper.
Yes, one at a time, start with the left side (if sitting on the bike)
Matt
Posted: Thu Apr 08, 2010 9:39 am
by Hogdigerdy Dog
Hi Kris
try this out for size, looks like it's just what your after from the wiki on fzronline
http://fzronline.com/wiki/doku.php?id=b ... _5_minutes
steve
Posted: Thu Apr 08, 2010 10:01 am
by Cammo
Let the fun begin!
Posted: Thu Apr 08, 2010 10:05 am
by Malc
Draw the fluid from the master cylinder to the caliper, starting with the longer of the two lines, then the shorter. Remember to keep the reservoir filled. Once you have fluid from both, keep going until you get a fairly bubble-free draw from each, then bleed them as normal. Job done, easy, everyone's happy!
PS - make sure you get a nice and tight pushfit onto the bleed nipple or you'll never get a good bubble-free draw! :)
Posted: Thu Apr 08, 2010 5:57 pm
by ibby4585
stupid question part 2: do you re-use the bled brake fluid? ie: refill the resevoir from the bottle im using??
Ta
Kris
Posted: Thu Apr 08, 2010 6:27 pm
by mattUKNC
I wouldn't, new fluid all the time.
Posted: Thu Apr 08, 2010 6:38 pm
by Drunkn Munky
reusing the fluid bled though is not a good idea as it'll have air bubbles in it.
get a mitivac, 5 min job
Posted: Thu Apr 08, 2010 8:39 pm
by ibby4585
Right, all bled, i had slight weeping on the right bleed nipple when bleeding, so im leaving it overnight with the brake depressed, then im going to bleed them again with the nipple sealed somehow. But to be honest the brakes are really firm just as good as my other bike.
pretty much sorted!!
Posted: Thu Apr 08, 2010 9:55 pm
by LUCAS
Drunkn Munky wrote:reusing the fluid bled though is not a good idea as it'll have air bubbles in it.
Probably THE best tool i have bought!!! The job that is hated has been turned into something i enjoy... ok slightly too far
but its a brilliant piece of kit!
