nc30 carb question
Posted: Fri Mar 19, 2010 10:47 am
i have replaced my carb rubbers with new, have brand new plugs / battery and have serviced my carbs as per dataracer's guide. standard jets and have set the pilot to 2 & 1/2 turns out as suggested for a race can.
put everything back together last night fuel on, choke fully out & started her up and she fired first time!
query is she was reving around 6 thou which seemed quite a lot to me ( is this normal? ), so i though i would close the choke slightly to get her down to around 5 thou which i thought should be about right. strange thing was as i closed off the choke it made no difference ( it is operating correctly and the idle adjustor is in the same position as before) , i even closed the choke fully and she still ticked over at 6 thou.
she then started to warm up and settle down. i am going to get her on the dyno and get the best jets to do the job with the can etc once she is all road legal.
could i possibly need to alter the pilot settings a bit more? or could it be something else? if 6 thou is about right to start then great but am just a bit concerned the choke open or closed was not making a difference.
