HEL Rear brake line - Fouls exhaust
Posted: Tue Mar 16, 2010 7:57 pm
by vr46
Hi,
I have a HEL rear brake line on my NC29, however it is not such a perfect fit.
The brake line from the caliper does not neatly follow the lines of the swingarm and rubs / fouls on my exhaust.
Anyone else noticed this?
Re: HEL Rear brake line - Fouls exhaust
Posted: Tue Mar 16, 2010 8:00 pm
by tanuki
you sure you have fitted it corectly
pics please..
Posted: Tue Mar 16, 2010 8:18 pm
by vr46
Quick pic...
I do have an aftermarket exhaust system which may have reduced clearance, the angle on the banjo means I cannot adjust the kink.
Posted: Wed Mar 17, 2010 5:09 am
by GF Racing
Pretty sure the banjo is wrong at the calliper end - few years back Goodridge had the same problem - so myself and PDQ got this all re designed with the correct ends.
The standard Honda 29 calliper banjo is an odd one with an upturn and kink at the same time - bit difficult to desribe.
We try and keep the correct Goodridge ones in stock.
BTW have you tried reverse fitting it - not sure if you have the type where the banjos can rotate inside their crimps to aid fitting.
Hope that helps.
Posted: Wed Mar 17, 2010 7:53 am
by tanuki
not the greatest pics but to me it looks like your line is just to long..not the greatest pics but these are what I have of mine.
Posted: Wed Mar 17, 2010 8:39 pm
by Wozza
Can you pull the hose up through the middle clamp a bit, so there is more hose in the master cylinder half and less in the caliper half?
Posted: Thu Mar 18, 2010 7:35 am
by stimpy
ive seen 1 looped before making it to the rear caliper...
i'll leave it at that
stimpy
Posted: Thu Mar 18, 2010 8:14 am
by Cammo
Cable ties for the win...
