All went well, got them off quite easily, contacted Rick and got some of his RO needles and new float bowl gaskets sent out to me. (top bloke, great advice!) Went to local Shop and got some 120 jets, so gone up from 115/118 to 118/120
Cleaned carbs out fitted the new bits, drilled slides etc and all was good!!
Now while I was waiting for the bits from Rick, did some reading up on other peoples experiences on refitting carbs, it wasnt looking too promising so decided to wait till I had a whole day off to attempt this apparently horrendous job!
Today was that day and using the original serviceable rubbers I gave it a go..............Woohoo! Fronts in first, little squizz of WD40 on the rears and with a gentle manouvering of a screwdriver they plopped in on the first attempt!!
After I'd stopped doing backflips round the garden and randomly kissing people I went to tighten the carb rubbers clips and broke the first one straight away!!
Thankfully the mech at the local shop has an NC and is bringing in a new clip for me tomorrow! Yay!
Tightened all the others up ok, so thought ahh what the hell, put it all back together and it fired up as soon as the float bowls had refilled, readjusted the idle and shes sounding sweet as a nut!
Will fit the other clip tomorrow and then out for a run!
Just wanted to say that using the info and contacts on 400greybike, this job that I was dreading was all in all pretty painless!!
If youve been putting off doing this, do it, you might just surprise yourself!!
Cheers guys!!
