Page 1 of 2
Clunk when braking or going over dips in the road???
Posted: Tue Jan 26, 2010 5:21 pm
by Julesholling
My NC30 has just started producing a clonk or click sort of noise if i brake or go over a hole/bump in the road.
Never did it before and i'm wondering what it could be. Also makes a little noise if i push it forward and then pull the front brakes?
Was thinking it might be a loose brake pad but does anyone else have some idea what it could be? Something on the forks maybe? :pray:
Re: Clunk when braking or going over dips in the road???
Posted: Tue Jan 26, 2010 6:05 pm
by alexwitham
Headrace bearings.
Posted: Tue Jan 26, 2010 6:22 pm
by banoffee
rattly mudguard?
Posted: Tue Jan 26, 2010 6:28 pm
by Jas RVF
try and put your hand so it is touching either top or bottom yoke and the frame around the front of the bike, roll it a few feet than pull on the front brake, if you feel movement the it's head bearings. If not look lower down.
Jas
Posted: Tue Jan 26, 2010 6:41 pm
by viper_biker
Mudguard 1st,
Wheel bearings 2nd,
Head bearings 3rd,
Fork bushes 4th.
Check these and see what haoppens.
Posted: Tue Jan 26, 2010 7:19 pm
by pugparcels
saw this the other day on a friends bike, he had recently serviced the calipers and not tightened them back up properly so everytime he braked the calipers moved and caused a clunk. check this as well just encase.
Posted: Fri Jan 29, 2010 9:54 am
by Julesholling
Cheers for the help guys. Gonna check the bearings and brake calipers this weekend. Fingers crossed it's easy and simple to fix :grin:
Posted: Fri Jan 29, 2010 10:25 am
I'd go mudguard too :ninja:
Posted: Fri Jan 29, 2010 10:40 am
by Sligeach
depends what the cluck is like, if it hollow sounds like mudgaurd, if its more firm and metallic i say headraces.
if its the mudgard just tighten up the rings by packing the space between the rings and the forks with a layer or two of electrical tape/ptfe tape
Posted: Fri Jan 29, 2010 11:02 pm
by DoktorMandrake
I'm not sure I'd be able to hear a mudguard over my can. Headraces you can feel the clunk as it goes right through bars, same with wheel bearings, you can often feel them (usually only when really fuckin' worn though).
