My NC-30 Build Thread. Many questions!!!
Posted: Thu Jan 14, 2010 5:46 pm
OK So I thought it was high time to start a build thread here... here's the scoop. I happened to have a chance to pickup an '89 NC-30 for relatively short money. It has sat for ~3 years and been run at trackdays, and down at least once or twice. We started by tearing the thing apart and seeing what we had.
Here's how she started.
Yours truly after removing the rads... they're in rough shape and either need a lot of attention and rehab, or I could use some new ones.
Motor's out.
And she's apart... here's my buddy Derek (Degsy) who'se helping me out and offering the workshop space. He's got a soft spot for NC's as he grew up in London and used to see them everywhere.
A few weeks went by with the holidays, and eventually we got to have a look-see inside the motor:
Now it's impossible to see in the pics, but most of it looks up to snuff. The biggest wear issue we noticed was on the shift forks that have some fairly significant wear. We debated long and hard about what to do since they seem quite hard to get at to replace... but eventually we decided that this, coupled with the general age of the motor were enough reason to split the cases and do a full "whole hog" motor rebuild.
I'm planning to get a full rebuild kit from our own Rick Oliver :)
Now's where things get iffy and where I'd like some input... as I, and even Degsy and our motor builder are all new to the NC-30 or the V4's in general, but a motor is a motor and I'm sure we can get her back together in top-notch fashion.
What I'm curious about is, here's a list of thoughts to do while we have it apart....
- Port heads
- 5 angle valve job
- Skim / deck the heads
- Undercut the transmission
- Balance the crank, rods and pistons
What I s'pose I'm looking for are other things to do while we're in there? I would love to consider an overbore kit but that just doesn't seem to be in the budget (unless someone has some pistons and such they're looking to part with, of course!)
Otherwise, what are some lessons learned and general do's and don'ts here?
I've already decided I will NOT be doing an HRC spec carb setup, but will likely be looking for a ram-air kit to use with my stock airbox, and go with Rick Oliver's "road" carb stuff.
For what it's worth, I have a hand-made full Mercury 4-1 system with titanium end can that's brand new that will be going on :)
Anyway, I look forward to updating this thread as often as I can, and would love, love, love for anyone with solid experience to chime in and push me in the right direction! As $$ is tight, this will take a while, so we have the time to do things right the first time. This will be my track bike as I run a track day company over here with Derek and 2 other partners, so she'll see loads of track time and I *might* consider the odd race here or there... I'm just afraid it'll be too much $$ to get the motor competitive with the only class she'd be eligible for, which is Ultralight Superbike that includes modified Ducati 800SS', Hawk NT650GT's, and Motards of unlimited displacement.
I also plan to restore basically everything along the way (externally) so she will be quite the gem when I'm done!
Motor's out.
- Port heads
- 5 angle valve job
