The speedo drive cable is disconnected(waiting on replacement from Rick O) but the electronics are connected. Carbs have been stripped/ cleaned and balanced by me and intake rubbers show no sign of leaks using carb cleaner method. Would the restrictor be cutting in if the mechanical drive cable wasn't connected? Didn't think this would matter?
Where should I start checking? Fuel starvation maybe? How would I check this out?
The bike is completely standard/ standard jetting and pipe with new plugs/ filters and valve clearances all done. Bit gutted after all the hard work that it didn't run A1 from the off but suppose thats half the fun getting it sorted... Want to get it on track before summer ends so any help would be great...
Thanks in advance...
