Stock Dyno Run - Results to follow
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham » Tue Jul 21, 2009 3:21 pm
I have my Stock NC30 booked in for a dyno run on the 1st of August at Seastar Superbikes on the outskirts of Norwich.
The only reason for this run is basically to see how the engine has aged, what the RWBHP is, and if its fuelling correctly.
Prior to this, im lucky enough to steal a few hours of Rick Olivers weekend to get the carbs sync'd and a shim check/change to make sure its running as mother Honda intended it too.
Other than this, would there be any other checks/changes i should do before it gets a 20 minute thrashing :twisted:
I have changed the oil and filter 500 miles ago, chain and sprockets 4000 miles ago, air filter was removed/cleaned 500 miles ago, sparks plugs are being cleaned/changed when Rick has the bike as the top rad has is being removed allowing easy access to the front cylinders (why Honda put the front sparkies in such a **** of a position i dont know). Anything else i should do?
The guy on the phone said 'make sure your tyre pressures are accurate'...is he being serious? lol
This is my first ever dyno run so im new to this shizz :blowout:
Biff
Re: Stock Dyno Run - Results to follow
Post by Biff » Tue Jul 21, 2009 3:54 pm
Yes make sure the tyre pressures are correct, as you will get dodgy reading if under pressure, also make sure there is enough fuel in it and even take spare fuel.
alexwitham
Post by alexwitham » Tue Jul 21, 2009 3:57 pm
32 PSI rear. 30 in front? i cant remember :shock:
Shall i fill the tank up to the brim or will it weigh the bike down?
thanks
Biff
Post by Biff » Tue Jul 21, 2009 4:01 pm
Fill the bike up as the weight is not an issue as the bike is straped down heavily so the rear wheel dosnt move off the drum.
jowyvfr
Bike owned: Aprilia rs125, nc30,..Van Van!
Post by jowyvfr » Tue Jul 21, 2009 6:42 pm
I usually run 33 front and rear, as do many on here I{ think. This is what i've been recommended....but It might be wrong.
alexwitham
Post by alexwitham » Wed Jul 22, 2009 12:11 pm
awesome, thanks for that.
I take it chain tension is a thing i need to check prior to the run?
