Sprocket Bolt
- Reactions:
Sprocket Bolt
Hi Just wondering if the front sprocket bolt has a an anti clockwise thread before I put a big breaker bar on it ,as it is bleeding tight . Cheers
- Reactions:
- Reactions:
Re: Sprocket Bolt
Yeah it is a normal thread but think on it'll work tighter over the life of the chain. Lock the wheel and get a big f*** off bar and it'll eventually give. WD40 and rock it a bit and will give up the ghost in the end.
How hard can it be?
- Reactions:
Re: Sprocket Bolt
It took 8ft of scaffold pole to get mine off, and two people holding down the back of the bike so they can be fairly tight.
- viper_biker
- Reactions:
Re: Sprocket Bolt
Also, when you re-fit the nut make sure it's to the correct torque setting. I had my bolt work itself loose recently and it eventually broke the sprocket cover housing with the strees it put it under,
- Reactions:
Re: Sprocket Bolt
Hi Chaps
Thanks for that ,I kind of knew that it was a std thread but as it is going to take a fair bit of undoing, I just thought I'd ask. :D
