NC30 Jetting
Jac-al
Re: NC30 Jetting
Post by Jac-al » Fri Nov 30, 2012 1:43 am
my fueltap diaphram is a bit dodgy, how do i do the mod everyone is talkin about?
Cammo
Re: NC30 Jetting
Post by Cammo » Fri Nov 30, 2012 2:58 am
Your best bet is to replace the diaphram in the tap, Rick Oliver sells replacements.
I wouldn't recommend doing the hrc tap mod on a roadbike - it's unecessary and can lead to problems (any float valve leaks will let fuel into the cylinders, bending rods when you go to start it).
How to is here if you really must: http://www.akhara.com/nc30/fueltapmod/index.html
Jac-al
Re: NC30 Jetting
Post by Jac-al » Fri Nov 30, 2012 3:27 am
whats the site adress? if its costly ill try the mod
porndoguk
Re: NC30 Jetting
Post by porndoguk » Fri Nov 30, 2012 7:26 am
How old are you jac-al?
Delboy
Re: NC30 Jetting
Post by Delboy » Fri Nov 30, 2012 7:29 am
It's free.....nothing......just approx half an hour of your time.......... :tits:
Re: NC30 Jetting
Post by Drunkn Munky » Fri Nov 30, 2012 8:18 am
Think he meant how costly is the fuel tap repair kit, answer........a lot cheaper than a fucked petrol flooded motor which you just know is going to happen in this case dont you.
Jac-al
Re: NC30 Jetting
Post by Jac-al » Fri Nov 30, 2012 8:18 am
Why do u wanna know my age
Re: NC30 Jetting
Post by CMSMJ1 » Fri Nov 30, 2012 8:38 am
We've got a bet on it...
No - seriously - it is very obvious that you are a chap in the prime of his life..and so know it all, cannot take advice and want it all now.
Fix the bike properly...what is the problem? Your issue is a knackered diaphragm..so replace it.
If you decide to modify the tap then be prepared for flooded engine, forcing an oil change and all that ballache. It is not a good idea unless on a highly maintained race bike.
Delboy
Re: NC30 Jetting
Post by Delboy » Fri Nov 30, 2012 8:40 am
Jac-al
Re: NC30 Jetting
Post by Jac-al » Fri Nov 30, 2012 6:59 pm
Thanks guys but its not the tap or vacuum either had it tested. Ive had it, gonna send the bike in on Monday
