Page 3 of 3
Re: Won’t start
Posted: Fri Mar 27, 2020 7:38 pm
by Jordansilver1
Also are all rectifier on Honda vfr400 nc30 the same as my bike is a L plate 94 I see these for sale on sites with certain years but plugs look same
Re: Won’t start
Posted: Sat Mar 28, 2020 5:10 am
by magg
Given the conflicting readings between your dash mounted voltmeter and the charger, I would not continue to fault find until you have obtained a mutlimeter that can confirm either of the battery voltage readings.
Re: Won’t start
Posted: Sat Mar 28, 2020 6:54 am
by Jordansilver1
Ok thanks magg for your help really appreciate it I’ll pop down local bike shop later this morning to see if he can check the battery over
Re: Won’t start
Posted: Sat Mar 28, 2020 11:22 am
by Jordansilver1
Had battery tested in local
Shop he did a drop test and was 12.7v he said it was ok I also checked block on right side 3 yellow wires and all looks good so I better take it to local shop to do some tests
Re: Won’t start
Posted: Fri Apr 10, 2020 12:07 pm
by Jordansilver1
Fitted new battery and bike started on first go so took bike to local shop he tested the battery and all was good but when I started her battery reading 15vupwatds 17v he said I need a new rectifier and he gave me a price of £95 for a moss one plus fitting as the new one comes with a new block and he likes to cut solder the new block also
Re: Won’t start
Posted: Fri Apr 10, 2020 2:54 pm
by Jordansilver1
Rectifier I’ve been told is from electrex world RR58 £75+vat guy In local bike Shop said he would charge me to change the plug there is nothing know with my plug but he says it comes with new plug so he likes to fit it
