How to: fit a BMW s1000rr rear shock to a VFR 400 nc30
- Bike owned: LUKE@YORK on the old site!
Re: How to: fit a BMW s1000rr rear shock to a VFR 400 nc30
Any info on how high it will jack a standard 30 up by? Is it anything close to the nc30 jack up kit that RO sells at around 30-35mm?
What are the thoughts/general consensus on using one of these on a heavier rider, I'm 16 and a half stone?
Luke
Luke
Raised by at least 2"juggernaut wrote:Any info on how high it will jack a standard 30 up by? Is it anything close to the nc30 jack up kit that RO sells at around 30-35mm?
Luke
Youll need a heavier spring 850lb - 900lb
- Bike owned: MG v35 II, NC30, MG NF Mil.
What is the correct spring spec for a 13 stone rider(without gear) on the nc30 for this shock, ID:2.25'', L:7'', 800 or 825lbs?
Do you know a place to order cheap springs from Germany or the neighboring countries?
You can order from demon tweeks for under £35 delivered in the uk.krisztian_andre wrote:What is the correct spring spec for a 13 stone rider(without gear) on the nc30 for this shock, ID:2.25'', L:7'', 800 or 825lbs?
Not sure about shipping to else where
- Bike owned: NC35, Shand Stoater plus
Hi guys,
Will this work with a 35? Do I need to cut or file anything?
Thanks!
Thanks!
- iDemonix
- Bike owned: '92 NC30
I'm jumping on this bandwagon.
Current shock is FUBAR'd so just shelled out on a nice looking S1000RR shock. Where are you people buying your springs from? I'm 11.5 stone without leathers and gear.
Are these ok to use with a heavier spring without revalving? It'll be better than my stock shock which collapses if someone sits on the back whatever the weather, so it'll be going on my bike regardless.
Think I'll file down the shock itself though, rather than the frame mounts, to retain originality.
- iDemonix
Oh and not that I'm overly bothered, but out of interest, say I swapped to an 800lb spring, would I be able to carry a pillion of equal weight?
I think your just gunna have to suck it and see mate, until you guys start putting some miles on the shock no one knows how its gunna perform.
- iDemonix
Fair enough, well as I said anything will beat the current sponge I have as a shock!
