RVF Tyre & chain hitting?
Re: RVF Tyre & chain hitting?
Post by Drunkn Munky » Fri Feb 10, 2012 6:35 pm
marcus57 wrote:
niteblade wrote:160 rear and 525 chain will cause it to hit each other... tried and tested
Even with the rick Oliver kit?
I hope not or I'm stuffed
Surely its easier and makes more sense to just go for the 520 chain?
isca1987
Bike owned: Nc30
Post by isca1987 » Fri Feb 10, 2012 7:03 pm
I have just fitted the kit. It works really well £16 well spent.
marcus57
Post by marcus57 » Fri Feb 10, 2012 8:29 pm
Not when you have a brand new 525 renthal sprockets and chain.
mo haggs
Bike owned: bikeless
Post by mo haggs » Fri Feb 10, 2012 11:53 pm
it's got nothing to do with the pitch (525/520).
the pitch is the distance between the pins.
what makes the difference is o-rings.
the rubber o-rings sit between the inner and outer plates on each side of the chain,
they are approx 1.5/2mm and with one on either side of each pin.
that's approx 3/4mm wider than a non o-ring chain of the same pitch.
so if you have a 520 o-ring chain at 25mm wide, then a 520 non o-ring chain would be 21mm wide.
besides all that o-rings sap power and are irrelivent if you look after your chain properly.
EDIT http://www.sprocketsunlimited.com/Chain ... tions.html
mo haggs
Post by mo haggs » Fri Feb 10, 2012 11:59 pm
might i also add that when i bought my bike it had a 180 supercorsa and 180 diablo rain,
i ran both tyres with a non o-ring chain and had no rubbing (standard rear wheel and no spaceing kit either).
i bought a new chain (o-ring) and that was the first time a chain came into contact with the tyre.
ps. i could not afford tyres for my first season and had to use what came with the bike.
i now run 160's on the rear
Post by Drunkn Munky » Sat Feb 11, 2012 12:08 am
True but a 520 has to be marginally narrower as a 525 o ring touches and a 520 o ring doesn't, and that's on the same bike/tyres etc
mo haggs
Post by mo haggs » Sat Feb 11, 2012 12:14 am
same chain make?
Post by Drunkn Munky » Sat Feb 11, 2012 12:20 am
No just ditched the shagged 525 for 520 renthals so that's probably why.
