Found my leak
Re: Found my leak
Post by Neosophist » Wed Oct 10, 2012 11:20 am
Sam-NI wrote:Was losing a quite a bit of oil. Checked all the usual places. Then found this.
:down:
Nice!
You only need one stick but this will repair it if you dont mind keeping it as is (wrong and tatty)
http://www.ebay.co.uk/itm/Lumiweld-10-R ... 0531564152
Sam-NI
Bike owned: '89 VFR400
Re: Found my leak
Post by Sam-NI » Wed Oct 10, 2012 11:51 am
Well, when i'm finished with this piece of chewing gum, I might stick that on. Xivilia said it should hold.
Me? The 13th Duke of Wymbourne, Here? In a French maids finishing school? At 3 O'clock in the morning? With my reputation?
BINGEAU!
Delboy
Re: Found my leak
Post by Delboy » Wed Oct 10, 2012 2:24 pm
Yes but it needs to wriggly's gum as it has a higer heat tolerance over other brands :peace:
Sam-NI
Re: Found my leak
Post by Sam-NI » Wed Oct 10, 2012 2:42 pm
And you can also use the tin foil from wrigglys to camoflage the chewing gum weld, to retain your factory finish. So i'm told.
BINGEAU!
speedy231278
Re: Found my leak
Post by speedy231278 » Wed Oct 10, 2012 3:00 pm
If you use a cold flame, you can use the welding pack from eBay to fix the cover while on the bike without risking setting fire to the oil! :-)
