nc30 Battery flat
- Bike owned: VFR400
Re: nc30 Battery flat
At 5000 rpm with lights on you should see 13-14 volts at the battery terminals. Start checking the charging system. Unplug the rect/reg and measure resistance between the three yellow wires, should see about one ohm, and infinite resistance between any yellow wire and the frame.
- Bike owned: nc30
Thanks.
Should the bike be running to do this.
Thanks.
Rob.
Thanks.
Rob.
No, just connect the multimeter leads, with the multimeter set to 1 x ohms, to the yellow wires at the plug after you remove the plug from the rect/reg.
- Bike owned: nc30
Thanks.
I will ask my mate to come & check with his mtr.
I will keep you informed or if anybody any more advice please let me know.
Thanks.
Rob.
Thanks.
Rob.
- Bike owned: nc30
Hi my mate has not been round with his mtr yet.
But I took the reg of & unpluged it & one of the yellow wires in the plug was looked like it was all burnt & the same on the pin on the reg were it plugs in.
Hope this makes sense.
Any ideas?
Thanks.
Rob.
Any ideas?
Thanks.
Rob.
Yes check the wiring from the alternator to the rect/reg. It all has to be in good condition, no burnt contacts, broken wire etc. Have you done the resistance check yet.
- Bike owned: nc30
Thanks.
No not yet have to wait for my mate to come round with his mtr.
Could it be the pin in the conector block thats cousing the problem?
Thanks.
Rob.
Thanks.
Rob.
It will not help, perhaps but you still need to check the complete system. The resistance check on the three yellow wires will tell you if the is a problem with the alternator and its wiring. The other thing to check while waiting for your mate and hus meter is the alternator loom connector that is located in the V area above the crankcases. This connector and its three yellow wires can fail also.
- Bike owned: nc30
Hi.
I think it mite be the alternator I dont know for sure.
I wish there were somebody round here who could help me out not too. clever with elictrics ha ha ha.
How much of a job is it to change one & does anybody know how much they usely go for,
Thanks.
Rob.
Thanks.
Rob.
How do you know it is the alternator?
