520 C&S from B&C Express cost me about £60 delivered for 40T renthal 15T&14T Renthal
then the chain was one of ebay
its a 120 links long so youll need to cut off 16 links, using a grinder i found it easier to do that on the bench grinder,
http://cgi.ebay.co.uk/RK-520-MOTOCROSS- ... 4cf60bf32b
£24.99 Free P&P and it should come with a split link. youll need to maintain this chain however take it off every 500miles for a clean and re oil in Gearbox oil 90w
far cheaper and lighter and lose less transmission power than that of a 525 o ring
Chain Breaker/Rivet Tool
Re: Chain Breaker/Rivet Tool
- Bike owned: RVF400 NC35
iv'e used this breaker/riveter and it seemed good enough
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
- lukemillar
The RK chain breaker/riveter is by far the best I have used. Cost me an arm and a leg but, it was well worth the pennies. Others I have used, snap the pin after a few chains.
http://www.solomotoparts.com/catalog/RK ... 22972.html
The whale is good by all accounts, but it is worth noting that there are 2 types of rivet link- The hollow pin which is flared and the solid pin which is peened. I think the whale is designed to be used with the latter whereas the RK riveter is for the hollow pins.
- CRM
Whale does either, the copper hollow pins can still be peened, then a centre punch to flay the centre a bit too.
