Juddering while accelerating.
grandad38
Re: Juddering while accelerating.
Post by grandad38 » Tue Oct 27, 2009 8:50 am
hi have you changed the coils as i had this sort of misfire that caused a judder
as going up the gears off the start line on my race nc23
good luck dave :ninja:
Mikiboy
Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Post by Mikiboy » Tue Oct 27, 2009 7:39 pm
Is it an after market exhaist. Could just need setting up on a dyno if so.
Check wheels are balanced.
Also do you have in bar ends?
bluebird400
Bike owned: Honda CBR400 NC23 HRC
Post by bluebird400 » Fri Nov 06, 2009 10:36 am
I would take Mikiboy's advice. After market exhaust. Check if you have 4 pipes going into 2, then into 2 - that is the correct configuration. If you have 4 pipes that go straight into 1 then that is a cheapo after-market exhaust and you will get a flat spot when you try to accelerate which will pick up after a second or two. Only solution is a new exhaust.
Central Line in rush hour or the A40 by bike? - well Duh!
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Post by petrolhead19 » Fri Nov 06, 2009 11:28 pm
i have the same problem had it since i got the bike and i have tried everything but nothing works
so i just get use to it lol or i dont let it get to the point were it judders i just give it full throttle to get past it quick lol
but my judder goes on for ages if im doin slow speeds and yeah in every gear
