Handle bar grip changing
BillyBarcelona
Reactions:
Post by BillyBarcelona » Fri Apr 05, 2024 6:31 pm
Hi folks, on with my CB400 SF resto (1992) and the handle bar grips need changing, I've seen utube clips about removing old ones on newer bikes that have bar ends but the 400 has what looks like a plastic cap on the end of the bar.
Do I need to do anything to the throttle cable before destroying the current rubbers please?
cbr400rrn
Reactions:
Bike owned: NC29 CBR600F
Re: Handle bar grip changing
Post by cbr400rrn » Fri Apr 05, 2024 10:59 pm
I’ve never had a cb400 sorry so All i can suggest is take your time and assess how things are put together as you take it apart carefully
Foxy400
Regular Member
Reactions:
Bike owned: NC35 NC29 Bonneville CBR600F4i
Post by Foxy400 » Sat Apr 06, 2024 10:35 am
I've changed grips many times and never had to do anything to the throttle cable before hand. I remember the first time I tried it I spent a long time trying to peel the grip off :stupid: then someone suggested cutting it off :roll: so it was out with the Stanley knife.
Swingarm
Reactions:
Bike owned: AR 125, NC30
Post by Swingarm » Sat Apr 06, 2024 5:41 pm
If you have access to compressed air squirt some down under the rubber grip while you pull it away. Also works for putting them back on.
Or try WD40 but you'll have to do a good job cleaning that up. Brake cleaner also works as a temporary "lube" to slip new ones back on which will then evaporate. But make sure materials that will touch the cleaner are compatible.
Failing that, as Foxy says, cut the blighters off.
I can't imagine the throttle cable needs touching but could be wrong. Can you post pics?
BillyBarcelona
Reactions:
Post by BillyBarcelona » Tue Apr 09, 2024 12:58 pm
Thanks for the advice guys, I'll give it a go.
BillyBarcelona
Reactions:
Post by BillyBarcelona » Thu Apr 11, 2024 3:06 pm
Guys, I've now discovered that the bike had had heated grips fitted previously, I'm really cautious about damaging something from the original set up, do I just start stripping the old grips off and hope for the best?
Swingarm
Reactions:
Post by Swingarm » Thu Apr 11, 2024 3:17 pm
Never had heated grips.
But it sounds like it's not very easy to remove them if you want to keep them.
https://www.advrider.com/f/threads/oxfo ... ll.604773/
MadMotoUK
Reactions:
Post by MadMotoUK » Thu Apr 11, 2024 7:30 pm
Isopropryl alcohol squited down between the rubber and throttle sleeve/clip on will soften the glue allowing enough time to remove the grip intact.
