Running problem
demerdzhiev
Bike owned: NC21
Running problem
Post by demerdzhiev » Sun Mar 13, 2016 10:25 am
When the bike still hasnt warmed up yet it runs normall, but as soon as it warms its like the power is on 50%. I am guessing that this means that it runs too rich or it is something i have no idea of
Re: Running problem
Post by Neosophist » Sun Mar 13, 2016 11:37 am
demerdzhiev wrote:When the bike still hasnt warmed up yet it runs normall, but as soon as it warms its like the power is on 50%. I am guessing that this means that it runs too rich or it is something i have no idea of
you have many many posts up for many problesm with this bike
do you not have a local expereicned mechanic who can help you?
the bike soudns like it has been neglected and most likely has several issues.
some things can cause symptoms that look like other problems
online advice is not so good if you have a bike like this.
ideally you need to give it a full service, make sure valve clearances are ok, clean and reset carbs probperly checking jets / float ehights and needles / tubes.
make sure airbox is ok, fire it up and balance carbs
check fuel delievery is ok, check electrical system is ok.
problems with electric system can amek carb like issues, same with carb like issue looking electrical.
everything needs to be checked and elimiated as part of a good service and biek should be ok after that.
vfrman
Bike owned: NC30, 1098s
Re: Running problem
Post by vfrman » Sun Mar 13, 2016 5:12 pm
Don't forget the air filter. And might as well give all the fluids a change too.
