Never found any difference.
HRC never bothered to fit it on their RVF750 F1 factory endurance and RC30 superbike racers, [up to 1993] or the RC45 type RVF750 superbike spec endurance and superbike racers [from 1994]
Dave.
HOW TO: Fit the RC30 brake linkage to an NC30.
- Bike owned: ftr223 650 bros
- BillingCBR
Re: HOW TO: Fit the RC30 brake linkage to an NC30.
But then again how many things do we do that won't *actually* benefit us or our bikes? Fancy paintjobs, tiny bits of Ti, poncy top yokes and aly screen braces etcMalc wrote:So in truth its not going to benefit 99 percent of owners?BillingCBR wrote: Liz, simple answer, it helps prevent the rear wheel hopping under extreme braking by bracing the caliper against the frame rather than the swingarm.
Plus it looks pretty
Cheers, I haven't been able to find much info at all about it, so was just giving a really really dumbed down version from what I'd readUsername wrote: Not quite as simplistic as that.
When you brake with a conventional set up the torque reaction tends to lift the rear wheel off the ground. The RC30 linkage reverses the torque reaction to impart pressure on the swing arm under braking forcing greater contact of the tyre with the ground. Having used one on an NC30 for over 10 years I would not consider it to be 'trick' or 'gimmicky'. It's almost impossible to lock the the back up even in the wet. You can confidently trail brake into corners as well to adjust your line. I certainly wouldn't remove mine.
I have good news, my mates dad has recovered most of the use of his wrist after breaking it, so can go back to work and will machine me the spacers required to fit, I'm supposed to be going over with all the bits I've accumulated so far, and will see if he can have a technical drawing made so that the replica parts can be machined, will hopefully have it ready to go soon
- Bike owned: '89 Honda NC30, '08 Ducati 848
Sounds interesting - I might be interested... look forward to seeing the quote for parts
hi all
did these kits ever get sorted ?
