17" rear NC30 wheels
Does anyone know what other single bolt mounting wheels will fit on an NC30 without too much hassle and spending hundreds on nc35 ones??
Details would be a big help, as I'm building a race bike and getting close to desperate for a wheel
- thunderace
- Bike owned: R6, YZF600R
Re: 17" rear NC30 wheels
I believe some Ducati wheels fit but I don't know what sort of work is involved.
- CRM
Either use the VFR750 wheel with rick olivers hub conversion, but its often just less stress and easier and not much more expensive to just buy a 35 wheel.
- thunderace
Paul, does Rick's conversion change the VFR750 wheel to single nut fitting from the original four nuts?
- JC120
- Bike owned: NC30 NC35 RC30 RC45 MC22 NXA
No it doesn't. It uses the 4 bolt pattern.thunderace wrote:Paul, does Rick's conversion change the VFR750 wheel to single nut fitting from the original four nuts?
V4ia addict
The best option is just to get the NC35 wheels. There may be others about that fit the single nut axle but they'll be more expensive. The VFR750 wheels are heavier (and not that much cheaper than NC35 wheels) and you'll need either the RO axle mod, or a modified VFR750 axle.
For racing. Easiest to buy the NC35 wheels. My $0.02 worth.
old thread revival batman
but looking into getting a 17" rear wheel and wondered if anyone knows of other wheels than NC35 or VFR750 that can fit or be made to fit?
please :)
please :)
- jim157
Bros 400 17" rear, MC28 rear (same as NC35). Ducati rears can also be made to fit with some modifications.
AUTOEXEC.TWAT
thanks jim
