VFR400z - green wire off rectifier?
Dpazza
Post by Dpazza » Mon Jul 21, 2014 9:39 am
Hi, I have an NC21 400z, when mending some holes in the tank I noticed that the green wire from the rectifier is not connected to anything. It has a circular end as it is screwed to something? Is it a feed from the battery or where should it attach to? I can add a photo if easier to explain.
Dave
Re: VFR400z - green wire off rectifier?
Post by Neosophist » Mon Jul 21, 2014 10:22 am
it didnt have a green wire on the original rectifiter.
it sounds like an earth wire if it has a ring tab on it, if itsnot attached and not causing any issue i wouldnt worry about it.
EvanTate
Bike owned: VFR400 NC21
Post by EvanTate » Mon Jul 28, 2014 12:50 am
Yea it's a different rectifier. Green is earth and would normally connect to the black wire in the VFR loom, but as Neosophist said, if it's not causing problems don't stress. Just check your charging voltage to be sure though.
