Any ideas if its supposed to go anywhere? or do i just need a replacement bit of pipe?
Many thanks James
That'll teach me for englarging the picture :Darsey30 wrote:Hose not required, that is just the tap breather inlet/outlet.
The vacuum hose goes on the forward facing tap stub, the other end onto the cylinder head screw in spiggot.
They use lots of fuel, I would not worry if I found no leaks, and the bike went well.
If that [not required] hose is blocked, then fuel flow may be reduced.
