Fuel pump wiring NC23
jonhunt
Bike owned: Kawasaki Z1a,Honda NC23j
Post by jonhunt » Mon May 26, 2014 10:14 pm
Looks like at some point the fuel pump relay has been taken off my bike. I'm not sure how the wiring should look. Currently the pump plugs into a flying lead (Y shaped) that joins to two points on the main harness. This separate lead has been cut about somewhat & I'm not even sure it should be there. If someone has a pic. of the set up in this area it would be a great help
OK sorted now with gratefully recieved help from GFracing. Hopefully this will sort the fuelling issue too
