NC30 with 35 carbs choke question
Adderboy
Post by Adderboy » Thu Apr 24, 2014 12:47 pm
I need to order a new choke cable for my NC30, but its got RVF carbs on it, just wanted to check which cable i should get, if they are different atall before I order.
CRM
Admin NWAA
Admin NWAA
Re: NC30 with 35 carbs choke question
Post by CRM » Thu Apr 24, 2014 6:30 pm
Makes no difference. Nc30 choke will be fine
Adderboy
Post by Adderboy » Thu Apr 24, 2014 9:05 pm
Thanks very much
royster81
Post by royster81 » Thu Apr 24, 2014 9:39 pm
I've an nc30 choke on my RVF carbs.
Adderboy
Post by Adderboy » Fri Apr 25, 2014 3:48 pm
OK thanks, I'm also going to need an idle adjuster cable, I'm guessing this is the same too?
I'm also struggling to find one, so if anyone has any ideas that would be appreciated
Edit
Just to clarify, the screw is not stuck, the cable will not turn independently to its sheathing so adjusting the idle means unclipping the adjuster knob and turning the whole cable assembly, which is aggro if you just want to adjust it with gloves on lol
royster81
Post by royster81 » Fri Apr 25, 2014 10:06 pm
The idle adjusters are different
