Headlight issue
jamie125
Headlight issue
Post by jamie125 » Sun Jul 14, 2013 9:02 pm
Have noticed that my sidelights will not work, but do come on when the main headlight comes on, I suspect it's something to do with the LH switchgear, anyone else ever experienced this?
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: Headlight issue
Post by hardnutdvd » Mon Jul 15, 2013 11:25 am
hey Jamie. it could be the LH switchgear. usually burnt out by heaving the incorrect wattage headlight bulbs installed
edit, where in Leighton are you? I was born and bred over there....
jamie125
Re: Headlight issue
Post by jamie125 » Mon Jul 15, 2013 2:07 pm
Have had the switchgear apart all looks fine, will have to get the multimeter out and give it a proper checking out. I live just off Johnson Drive by the McDonald's, lived here for 2 years, moved over from dunstable. 8-)
hardnutdvd
Regular Member
Re: Headlight issue
Post by hardnutdvd » Tue Jul 16, 2013 10:28 am
did you check the bulbs were correct?
Mine didnt actually look burnt out either... but it was the problem
