NC30 choke cable question
Haydn
Post by Haydn » Sun Jun 09, 2013 8:34 pm
I've just replaced the choke cable before putting the carbs back on. What actually holds the outer part of the cable in the lever housing? There's nothing to stop it pulling out. The one I took off had a couple of cable ties holding it to the housing bracket. Am I missing a small clip?
Re: NC30 choke cable question
Post by CMSMJ1 » Sun Jun 09, 2013 9:23 pm
The lever on the carbs? It has a little bracket that screws on.
Haydn
Post by Haydn » Sun Jun 09, 2013 10:20 pm
No, the lever you use to apply the choke. The carb end is clamped but there is nothing to keep the cable in the plastic housing the other end. It's no bother I will just use cable ties to hold it in place again put just wondered how it should be from the factory.
