I have just removed my rocker covers and instantly noticed a small 3x5mm dowel or roller nesting in the corner of the front right cylinder!
Can anyone tell me how to download photos... sorry, im a new to greybike
can anyone identify this, found loose by my rockers!
- lukemillar
Re: can anyone identify this, found loose by my rockers!
Won't be able to confirm for sure without seeing a pic (I usually just host them with someone like imageshack and embed the link here) but it sounds like one of the locating pins for the backlash gears on the camshafts. Not sure how it could get out though, but I'd remove the camshafts and check if one is missing. The backlash gears are just held on with a circlip.
Luke
Luke
Your a pro! The quietening gears had been removed by the previous owner... lets hope thats all he did!
CHEERS
CHEERS
- lukemillar
That'll definitely be it then. The pin can look like it is a fixed part, so the previous owner might not have realised it was removable and it juts rattled loose. Maybe check the others if that is the case
Definitely, im gonna drop the sump too, you never know what i might find!
Thanks again
Thanks again
