So I have just finished putting my little NC30 engine back together.
It was looking pretty sorry for itself when i pulled it out of the frame so I got the top case painted, and whilst it was apart, I fitted a set of NC35 pistons and new rings, lightly ported the head, re cut the valve seats to three angles, ported the ex manifold, lacquered the heads and cam covers and re set the valve clearances with new shims and brand new inlet rubbers.
Got the engine back in the frame, but forgot to fit the manifold, so I had to drop the swingarm out to get it in (not easy), then put the swingarm in and connect the linkages which it didn't want to do without a fight the as the exhaust was in the way). Tonight, I'll put the front exhausts on, bottom rad and then change the float needles as some are worn - hopefully this week I'll get it started.
