Crush washer
gazm
Crush washer
Post by gazm » Sun Jun 03, 2012 12:08 pm
I am about to change the fork oil seals on my K model 1989 NC30. My haynes manual says to use a new damper rod crush washer. Is this necessary or could I use the same one, I'm only asking as I was going to buy the seals from wemoto and they don't list the washer. If it is where is the best place to buy one. Also they reccomend changing the dust seals, is that necessary to? I'm sure I didn't used to change those everytime, or am I just a shoddy, tight mechanic? Cheers for any help.
OllieH
Bike owned: NC30 Type 3, Bandit K8
Re: Crush washer
Post by OllieH » Sun Jun 03, 2012 1:15 pm
It's a personal one really. I would recommend replacing the crush washer but I bet many people wouldn't bother. Brake calliper mounting bolts are pinch bolts so should be replaced every time they're removed buy very rarely are. I guess it saves the hassle of having to take them apart if they needed replacing later on. Same with the dust seals unless they're In real good shape, they wouldn't cost much.
oldgreyandslow
Bike owned: 1990 NC30
Re: Crush washer
Post by oldgreyandslow » Sun Jun 03, 2012 9:10 pm
gazm wrote:I am about to change the fork oil seals on my K model 1989 NC30. My haynes manual says to use a new damper rod crush washer. Is this necessary or could I use the same one, I'm only asking as I was going to buy the seals from wemoto and they don't list the washer. If it is where is the best place to buy one. Also they reccomend changing the dust seals, is that necessary to? I'm sure I didn't used to change those everytime, or am I just a shoddy, tight mechanic? Cheers for any help.
David Silver Spares have them http://www.davidsilverspares.co.uk/part ... mber_5385/
I believe you can reuse them if you can heat it to red heat and leave to cool, however for £1.10 each I'd break the bank ;)
Tomzed
Bike owned: Yamaha wr125x and Nc30
Re: Crush washer
Post by Tomzed » Sun Jun 03, 2012 9:24 pm
If you can wait til after the bank holiday mate send me your address and I'll post you 2
gazm
Re: Crush washer
Post by gazm » Wed Jun 06, 2012 11:19 am
I never thought of Dave Silver, Makes life easier, Cheers.
