bleeding the clutch
bullitt
Bike owned: vfr400 nc21
bleeding the clutch
Post by bullitt » Tue Jan 31, 2012 11:34 am
hi is bleeding my clutch the same procedure as bleeding the brakes
cheers
Chrissy_J
Bike owned: VFR400Z NC21
Re: bleeding the clutch
Post by Chrissy_J » Tue Jan 31, 2012 1:31 pm
Yes, it's exactly the same principle, with the same procedures.
I had problems at first because I had to fit a banjo bolt with an integrated bleed nipple (the original bleed nipple on the clutch slave cylinder was seized) and so there was an air pocket above the bleed nipple. Taking the slave cylinder off and turning it slightly, allowing the air to escape, solved that.
bullitt
Post by bullitt » Tue Jan 31, 2012 5:15 pm
thanks for that
