where do you get slider pin grease
will lm grease be okay am rebuilding rear calipers
cheers
sliding pin grease
- Bike owned: vfr400 nc21
- Bike owned: 1990 NC30
Re: sliding pin grease
cheers just ordered some
don't use that for sliders.
Use it on pistons and rubber seals to help locate them.
It's good stuff and I always use it on pistons etc but it's vegetable oil based, will melt too easily.
http://www.ebay.co.uk/itm/Silicone-grea ... 48435811be
Some high temp silicone grease is rubber safe. The stuff Honda use is oranage I believe.
Make sure to flush all the old grease out first, if the rubber seals are swollen from previous grease or cleaning sprays then replace them
- Bike owned: SV650S, NC24
Correct! Red rubber grease is however perfect for carb diaphragms
