Clutch question
Clutch question
Ok, got a question about the clutch basket. I have the clutch nut torqued to 85Nm, which is the correct spec. When I grab the basket, I can wobble it a tiny bit, from side to side. Is this normal?
Re: Clutch question
pretty sure mine moves..
Re: Clutch question
Ok sweet. I've just had to replace an input shaft because of a stripped thread, this stripped thread was found from the clutch slipping all of a sudden. We didn't find any problem with the clutch at all, so assumed the thread was damaged and then eventually gave way, which caused the clutch to slip. Hopefully the problem has been remedied, otherwise I'm completely out of ideas as to how to fix the clutch.
And hopefully there's no oil leaks. Please please please no leaks
