I'm new to this so please bare with me.
Ok,
So i've had the bike a year, Never any problems with starting.
I took the bike in to get a standard rear silencer re fitted as it had an aftermarket race can on.
the bike was fine,
I booked a track day and decided i wanted a race can re fitted so i bought a new one from ebay which stated the bike wouldn't need re jetting for it to work.
I picked up the bike from the garage, it started but felt very underpowered. I reved it up to 7000 rpm a couple of times, it back fired then cut out. After this it wouldn't even come close to running. In fact the starter motor would just spin with no fire up.
Because i hadn't realised these bikes do not like throttle when starting, i believe i flooded it. hmm
SO,
i looked on here and asked around , checked the fuel to carbs. ..fine
checked spark fine but weak
they were oily though.
cleaned the plugs and put it back together.
still wouldn't start from electric start up.
Then i decided to try to bump start it. IT Worked. :) ( which was lucky as i had booked a track day the next day.) SO happy
i left it running until warm then turned it off. all good..
Then,
Got to the track the next day. fired the bike up. NO problems.
Done 5 sessions without any problems however the bike didn't feel as fast throughout the whole rev range as it used to.
Sixth session the bike died. same problem as when i tried to pull it out the garage, now it just won't start.
Tried removing the plugs and cleaning them as they were black. and a bit oily towards the top end of the thread near the nut that tightens them in. (?)
i adjusted the spark clearances at the end of the plugs to the correct 0.7mm
i tried for spark again on all four plugs, the were firing but intermittently. sometimes working sometimes not. i tried changing plugs around. I'm just getting a mixed bag of sparks. very temperamental.
could it be the coils? or the leads? or plugs.. or the lot.
Any help would be appreciated.. I'm thinking change the plugs, leads, and coils packs front and back.
I want to get this running pronto as I've bought an R6 and need to sell the NC.
