Rear brake fluid top up?
Zadkiel
One Hit Wonder
Post by Zadkiel » Wed Jun 22, 2011 8:19 am
The rear brake reservoir on my 2000 CB400SF has a metal bracket above it, so I'm not to sure how your meant to open it. Do I have to unbolt it, or is the some trick to it?
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Rear brake fluid top up?
Post by amorti » Wed Jun 22, 2011 8:36 am
Zadkiel wrote:The rear brake reservoir on my 2000 CB400SF has a metal bracket above it, so I'm not to sure how your meant to open it. Do I have to unbolt it, or is the some trick to it?
You shouldn't ever need to top up the fluid. If it is low, then it probably means your pads are nearly worn out. Replace them and the fluid will be full again. Or it means it's leaking, then you should replace the seals.
Otherwise, you can unbolt the reservoir from the bike to fill it, makes things easier.
