Frame/ swinging arm advice needed
robsturrs888
Post by robsturrs888 » Mon Apr 18, 2011 9:31 am
Hi, i could do with some advice as i am thinking about powdercoating my frame and swinging arm, but im worried about the cost of all the bearings and seals that will need replacing. Does anyone have a rough idea what needs to be changed, how much it ll cost and also wether theres anything i can reuse. I dont want to get the powder coating done to find i have another couple of hundred to spend to put it back together. Thanks for any advice :)
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Frame/ swinging arm advice needed
Post by amorti » Mon Apr 18, 2011 10:30 am
robsturrs888 wrote:Hi, i could do with some advice as i am thinking about powdercoating my frame and swinging arm, but im worried about the cost of all the bearings and seals that will need replacing. Does anyone have a rough idea what needs to be changed, how much it ll cost and also wether theres anything i can reuse. I dont want to get the powder coating done to find i have another couple of hundred to spend to put it back together. Thanks for any advice :)
You will have to renew steering bearings (cost <£30 for needle bearings)
and you will have to replace the swingarm bearings. I am not sure about the cost of them, but it's usually itro £30. To be honest, on most bikes of this era it's generally a good plan to replace these by now anyway.
robsturrs888
Post by robsturrs888 » Sat Apr 23, 2011 2:12 am
thanks for the advice, think i will get it done when ive got time to strip it down.
