Generator Fly Wheel Rotor
Claytonbojo
Bike owned: VFR NC30 NSR125, Pit bike 200C
Re: Generator Fly Wheel Rotor
Post by Claytonbojo » Tue Apr 12, 2011 8:20 pm
thanks for the replys people i got the tool to take the cover off isnt the geny ment to be sealed so no oil get's on the geny? i haven't seen inside the fly wheel yet but when i took the engin cover off abit of oil came out so i was thinking abit of oil has got in on to the geny?? i also got a 20m peugeo sump plug to fit on to the fly wheel so it will pop off nicely :grin:
Post by CMSMJ1 » Tue Apr 12, 2011 8:26 pm
You can see the crank inside the genny cover...so it splashes a bit of oil about. Normal... :ugeek:
STYLER
Post by STYLER » Tue Apr 12, 2011 11:22 pm
If you look in the Haynes Manual, which you should have! :? it says that a rotor holding tool can be easily made from two strips of steel bolted together in the middle, and with a bolt through each end which locates into the two holes on the rotor face. I think you can also just put the bike in gear and hold the rear brake down to stop the rotor moving if you dont have the tool, according to the Haynes bible!!
I might make one of these when i do the GSXR conversion with a 2006 1000 flywheel and stator and the new design cover i got from radprecision on ebay (they produce them for Rick Oliver)
I saw a similar design with a VFR logo on it a while ago on ebay which someone on here has. I wasnt keen on the adapter plate that bolts through the stock cover on the old design and i hoped the original one piece cover design would be made again and i was chuffed to see my dreams come true!!! :grin:
Heres the cover and its very nice in the flesh!! :drool:
slowsport
Bike owned: NC35
Post by slowsport » Fri Apr 15, 2011 4:48 pm
porndoguk wrote:DIY lads, only need a few strips of 4-5mm steel :)
i made one for a mate to get his sprocket off his GPZ900R
hes the pic i made him,
hey and his name is steve too, i could say i made the pic for you too
:plus: lol i made one of these also! worked a treat
