Ignitech CDI question
Re: Ignitech CDI question
Post by Drunkn Munky » Thu Mar 31, 2011 9:26 am
Theres a correction adjustment on the misc tab to adjust the output to the standard tacho.
porndoguk wrote:ive communicated and had a little play, i set the RPM to 5k and ill be damned it works!
What do you mean set the RPM to 5k???????
banoffee
Post by banoffee » Thu Mar 31, 2011 9:57 am
I assume that's meant to be 5% as I set mine to the exact same :grin:
porndoguk
Post by porndoguk » Thu Mar 31, 2011 10:05 am
Drunkn Munky wrote:Theres a correction adjustment on the misc tab to adjust the output to the standard tacho.
it was 11pm and i didnt fancy reving the bike to 14.5k to see if it worked! :whistle:
so i set it to 5k then set it back to 14.5k :mrgreen:
porndoguk
banoffee wrote:I assume that's meant to be 5% as I set mine to the exact same :grin:
cheers Steve ill try later steve, just found me an usb extension lead so i can put the laptop on the bench rather than the pillion seat :shock:
Post by Drunkn Munky » Thu Mar 31, 2011 10:25 am
porndoguk wrote:it was 11pm and i didnt fancy reving the bike to 14.5k to see if it worked! :whistle:
:lol: they'd be WW3 where i live if i rev'd my bike upto to 5k at 11pm, infact even starting it at that time would result in rotten eggs launched in my direction.
porndoguk
Post by porndoguk » Thu Mar 31, 2011 10:32 am
I have a primary school one side of me, and my other neighbour is my mum :D
the house behind is rented to some troublesome dykes so i dont mind pissing them off, its the olds next to my mum, but they arent my neighbours so feck it!
5k is me being reasonable bearing in mind the tyga can ticks over at 98dB :ban:
