carb trouble!
stevie
Bike owned: 92 uk model nc30
carb trouble!
Post by stevie » Tue Mar 29, 2011 7:33 pm
Hi all, its been a while since iv been on here, the site has changed a lot & looks great, glad to see good advice is still being given as im in need of some. just over a year ago i had a bad accident on my winter bike so the nc30 has been sat idle for all this time, when i tucked her up she was runing perfect but on trying to start her at the weekend she dident want to go, i managed to get her started but she was backfireing and when i cracked the throttle open fast she would die, iv discovered that the front two cylinders had filled up with petrol so i took the carbs off cleaned them out checked the float heights and the float switches which all seem to be working as hey should, but when i re fited the carbs it done it again, has anyone got any ideas what if not the floats can cause this?
Any help would be greatly appreciated. my bike is a 92 uk mdel nc30 with nc35 carbs running the full hrc carb kit and airbox set up with a modifyed filter, im running 142/145 mj, hrc emulsion tubes, vell stacks, & slide springs, using the B needles on the longest setting, i allso use a small k&n crank case filter, nc35 cams, and a load of other mods but the above is all that would effect fueling. Thanks.
Re: carb trouble!
Post by CMSMJ1 » Tue Mar 29, 2011 8:10 pm
Howdo Stevie,
Used to be a taxi driver in Liverpool eh? That you? Yellow tyga racebike??
I'll bet you have ER10 plugs in it...and they are dead. New plugs man.. ;)
stevie
Re: carb trouble!
Post by stevie » Wed Mar 30, 2011 7:13 pm
Ha, no sorry mate not me, im in Aylebury, iv put new plugs in but that wouldent cause petrol to leak into the front two cylinders, as far as i can see the only thing that would cause it would be the float switches but as i said they are all in good order and working as they should, float heights are spot on so im prety much out of ideas, and i dont fancey having to buy another set of carbs. any ideas? if iv done it rite there should be links to a couple of pictures of my bike below?
http://i429.photobucket.com/albums/qq12 ... C00246.jpg
http://i429.photobucket.com/albums/qq12 ... C00095.jpg
