Yes if the carbs have been modded for ram air then yes it will only work with that setup, im not sure what you need to do to the 35 carbs for ram air as i had the 30 carbs and someone else modded them but i know theres various plumbing mods that your need to reverse. What you need is good standard set to compare them with.spanky wrote:Perhaps the other way around is to ask how a proper ram air sysytem behaves without any airflow? IF the carbs have been modified is it possible that it will only run right with a pressuriesed airbox?
Shorts stacks
Also im not saying the fuel pump couldnt be made to work but you dont need it for a non ram air setup, NC's are sensitive enough with regards to fueling without adding the problem. I like the idea of having one so it shuts the fuel supply off automatically but im not brave enough to try it
