Nc30 chain & sprocket fitment
ChowderV4
Bike owned: 94 Fzr 400 3TJ ZXR400 Racer
Post by ChowderV4 » Tue Jan 18, 2011 6:02 pm
I've just fitted a chain and sprocket today and have tightened the adjuster up as much as possible but there is still an extreme amount of slack.
its that Chain and Sprocket set.
any ideas?
http://cgi.ebay.co.uk/VFR-400-R3-LM-NC3 ... 4aa567fd19
banoffee
Re: Nc30 chain & sprocket fitment
Post by banoffee » Tue Jan 18, 2011 6:08 pm
standard size sprockets?
have you moved the hub through 360 degrees?
might need to take a couple of links out if so
ChowderV4
Post by ChowderV4 » Tue Jan 18, 2011 6:11 pm
Chain 525 -108 links
15 tooth front
40 tooth rear
Thats what the new kit is and i was running the same before i changed it.
maybe it does have too many links, whats standard gearing and link count?
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 » Tue Jan 18, 2011 6:52 pm
15/40 104 links.
Some suppliers give a standard length to cover various models.
I leave the adjuster in the existing position, then fit the chain to check length. [ in case I miscount number of links and remove too many :-( ]
Dave.
ChowderV4
Post by ChowderV4 » Tue Jan 18, 2011 7:03 pm
alritey, cheers dave.
The father is coming up on the weekend with a grinder so we shall remove a few.
