RVF400 trouble, possibly worse.
Re: RVF400 trouble, possibly worse.
Good point.. its an RVF... I really should start reading the threads properly
Just to point out that these air scoops are important on a standard road RVF as they direct cool air to the front of the air box intake snout. The VFR has a small plastic scoop that directs it in from over the top of the upper radiator.Drunkn Munky wrote:Ok that tyga part is called a tank apron, those 2 holes have nothing to do with breather pipes. You should have 2 plastic air ducts that attach to them and the holes in your front fairing, don't panic If you haven't as they are of no use at all apart from looking good.
- superlite
- Bike owned: TLS, LB80 x 2
RVF snorkels are dummies designed to mimic the RC45 snorkels (that do perform the induction function). The NC35 gets its air from the same place as the NC30rvfhonda wrote:Just to point out that these air scoops are important on a standard road RVF as they direct cool air to the front of the air box intake snout. The VFR has a small plastic scoop that directs it in from over the top of the upper radiator.
'Take it to the Back'
Not being picky but I'm right in what I said. On the RVF in standard form there is a rubber seal that sits under the front portion of the frame. This stops any air passing up over the top radiator. This then acts as a sealed area to catch the air that comes in via the air scoops down the front of the fuel tank to the area where the snorkel on the air box lid sits. That is why there is a rubber seal around the front of the tank cover. Not ideal I know but it works to a point.superlite wrote:RVF snorkels are dummies designed to mimic the RC45 snorkels (that do perform the induction function). The NC35 gets its air from the same place as the NC30
