nc24 clutch hydrolic upgrade
Re: nc24 clutch hydrolic upgrade
try a brembo of a m/cylinder off a 916.
14mm comes to mind... same as the brake lever?royster81 wrote:what size is the stock clutch master cylinder as i wanna find one that has a bottle like the brake lever rather than the metal res.
also if you guys see any of these parts cheap give me a shout as i'm going to try and fit one of these to an NC30
- royster81
http://cgi.ebay.co.uk/HONDA-VFR400-NC21 ... 5887dea0b8
is this the sprocket cover i'm looking for ?
and did you mean the nc21 pushrod is longer than the nc24/30/35 rod,in which case what size and we'll see about getting one made.
Thats the sprocket cover :-)royster81 wrote:http://cgi.ebay.co.uk/HONDA-VFR400-NC21 ... 5887dea0b8
I have 2 sprocket covers.. I think one of them might have a crack in it but your welcome to have it if your going to be modding it anyway :-)
I probably have a slave cylinder to go with it!
And yes.. the hydraulic clutch rod is about 1cm longer than the non-hydrolic rod as the slave cylinder doesn't move as far as the cable clutch!
