fault(electric?)
fault(electric?)
intermittent fault, starts aND RUNS normally,sometimes as long as 2 weeks, then will just stop as tho keys been turned off,either leave for an hour, or jump with leads and it,ll fire up!!baffled!!ted p.s new battery fitted..
- Matchlessman
Re: fault(electric?)
Hi Ted,
are the battery terminals done up tight?
Other than that, check to see if you have trapped wire or something? does it make any difference if you move the steering?
- mattUKNC
Matchlessman wrote:Hi Ted,
On anything that might have been moved/ knocked while changing the battery.
My negative term came very slightly loose, bike still ran fine but I lost power to the satnav, 2 further turns down and all was well!
Fingers crossed it's a simple fix!
th anks for replies,but it did this before i changed battery,there is some wiring from it having at sometime an alarm,may be this?..but i,m crap with electrics, i got aa out last week, it starts with jump leads, but turns over well on it,s own..baffled, durham!!
ted
