Need a bolt! but have no idea what type or size!
Re: Need a bolt! but have no idea what type or size!
The clocks on my NC24 were quite loose even though the mounting nuts were tight, the rubber bushings holding them in place were aged and had shrunk, i had to fit larger inside diameter washers behind the original washers to take up the slack. Clocks now fixed tightly.
