Hi,
I have a HEL rear brake line on my NC29, however it is not such a perfect fit.
The brake line from the caliper does not neatly follow the lines of the swingarm and rubs / fouls on my exhaust.
Anyone else noticed this?
HEL Rear brake line - Fouls exhaust
- Bike owned: All sorts
Skint Novice F400
Re: HEL Rear brake line - Fouls exhaust
you sure you have fitted it corectly
pics please..
pics please..
Quick pic...
I do have an aftermarket exhaust system which may have reduced clearance, the angle on the banjo means I cannot adjust the kink.
Skint Novice F400
Pretty sure the banjo is wrong at the calliper end - few years back Goodridge had the same problem - so myself and PDQ got this all re designed with the correct ends.
The standard Honda 29 calliper banjo is an odd one with an upturn and kink at the same time - bit difficult to desribe.
We try and keep the correct Goodridge ones in stock.
BTW have you tried reverse fitting it - not sure if you have the type where the banjos can rotate inside their crimps to aid fitting.
Hope that helps.
Hope that helps.
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
not the greatest pics but to me it looks like your line is just to long..not the greatest pics but these are what I have of mine.
Can you pull the hose up through the middle clamp a bit, so there is more hose in the master cylinder half and less in the caliper half?
ive seen 1 looped before making it to the rear caliper...
i'll leave it at that
stimpy
stimpy
