Wire ratings
Spike16
Wire ratings
Post by Spike16 » Wed Dec 30, 2009 4:32 pm
Hi im building a race wiring loom for my ss400 bike and hence it needs to retain a gennerator and charging system.
my question is the red and white wire that goes from the main fuse on the starter relay to the regulator, does this need to be over 30amp rating? as the fuse is a 30 amp and also the other wire on the end of that fuse (red on original wiring diagram, black on mine as its going to the start/stop switch) does this also need to be over 30 amp rating?
all other wires I am using 16.5 amp rating thinwall wires as the only other fuses in the system are the ones for the clocks and idiot lights (10 amp) and the horn (10 amp).
Is their anywere else that needs a larger than 16.5 amp rating wire?
Re: Wire ratings
Post by Drunkn Munky » Wed Dec 30, 2009 6:37 pm
When i did mine i used the next size up from the 16.5 amp thinwall for those wires which IIRC is 32 ish amp. Also im pretty sure thats the only place i used the heavier gauge wire.
Spike16
Re: Wire ratings
Post by Spike16 » Wed Dec 30, 2009 9:01 pm
kl iv ordered some 32 of these aswell so thats all good
what about the yellow regulator wires? are they higher rating? also does that mean the black and white wire that comes from the switch that the black (or red on stock) wire connects to? this goes to the coils should this be higher rating too?
Re: Wire ratings
Post by Drunkn Munky » Wed Dec 30, 2009 9:20 pm
Yep used 32 amp for all the reg wires aswell. Not sure about the coil wire. Dont have the bike no more so cant check but ive got some notes somewhere i'll dig out.
Cammo
Re: Wire ratings
Post by Cammo » Wed Dec 30, 2009 11:25 pm
You'll be fine with standard gauge wire for the coils.
Spike16
Re: Wire ratings
Post by Spike16 » Thu Dec 31, 2009 3:44 pm
ok kl by standard wire guage you mean 16.5 amp right?
Cammo
Re: Wire ratings
Post by Cammo » Sat Jan 02, 2010 3:20 am
Spike16 wrote:ok kl by standard wire guage you mean 16.5 amp right?
Yeah that will be fine.
