Hi all,
It's been a while due to this freezing bloody weather but I've now made some more progress on the bike so thought I'd post an update - i need central heating in my garage!!!
I have now filled the engine with oil and have had it turning over, and I'm pleased to say its holding oil pressure so far. Next on the engine is a compression test and valve clearances. Here's ow the bike stands at the moment:
For the last week or so I've been battling with one of the blanking bolts in the inlets used for carb balancing, the two ourside ones came out no problem, but the inside two are at a really awkward angle and were already rounded off. In the end i had to drill them out and use an easy out, but it really wasn't that easy!!!
I've now replaced them with stainless bolts so shouldn't have the problem again. I've also stripped the forks now, and am awaiting new oil seals to get them back together. The swing arm was damaged from the accident, i managed to pick up a replacement on fleebay, so the new one along with the fork bottoms is off for powder coating tomorrow morning.
Whilst I'm waiting I've sprayed the bottom yoke, and am currently polishing the top yoke, results will be posted as soon as i can get some decent photos!
I cant warrant the expense of a stainless exhaust system at the moment so I decided to tart up the original, i was actually quite pleased with the results. Once the forks are back on and the bikes on the stands, it can go back on with the new gaskets and I'll be one step closer to having her running!! Cant wait!!
Before:
After:
I've also decided to stick with the 110 jets that are currently fitted, so the carbs are also going back together with stainless bolts, pics to follow.
Thats about it for now, i should get some more done over the weekend so i'll get some more pics then.
Cheers,
Matt
