how to open nc30 left hand switchgear
Posted: Mon May 21, 2012 2:38 pm
by makz2008
Hi all, my friend has an Nc30 which has a sticky switch,
we cant figure out how to open it up to have a look at the contacts/switches
any advice would be greatly appreciated
thanks
maks
Re: how to open nc30 left hand switchgear
Posted: Mon May 21, 2012 2:58 pm
by Man_Named_Dave
As far as I remember there are 2 screws on the underside and then you kind of crack it open. I'd put a white cloth underneath or similar to catch any bits that go flying.
Posted: Mon May 21, 2012 3:08 pm
by makz2008
ok il have another look,
but i only noticed one screw
Posted: Mon May 21, 2012 3:13 pm
by porndoguk
2 x Phillips screws, about m5/50mm youll need to tuge the upper or lower part to lossen from the bar, there is a retaining lug that sits in the handle bar so dont twist or youll snap it,
The wiring clamps into the upper part but there is wiring for the horn that also goes to the bottom part which makes it hinge off so to speak
Rick
Posted: Mon May 21, 2012 3:26 pm
by makz2008
thanks iv found them going to try getting it off now il let you know how it goes
Posted: Mon May 21, 2012 3:29 pm
by Man_Named_Dave
Be VERY careful if and when you prise the white plastic square out. The little springs and bits of copper are liable to fly anywhere and are a complete bugger to find on the floor!
Posted: Mon May 21, 2012 4:01 pm
by scooble
the high/low beam switch has a sprung ramp arrangement.
Everything stays in its place when you prize the halfs apart though.
Probably best to remove it from the loom and take it indoors. My hi/low was gunged up, but only toggles now if I hit the switch quickly
Posted: Mon May 21, 2012 9:06 pm
by iDemonix
Do it at your own peril, I opened my old semi-working one once, glanced in and decided to give it to Rick for free I believe :P
Posted: Mon May 21, 2012 9:34 pm
by porndoguk
iDemonix wrote:Do it at your own peril, I opened my old semi-working one once, glanced in and decided to give it to Rick for free I believe :P
Twaz the case as the writting was all white and nice unlike my nasty faded one,
Posted: Thu May 24, 2012 12:43 am
by makz2008
havent got around to doing this yet, may have a pop tomorrow so expect some noobish questions
