need swingarm pivot bearings, where?
PurPony
Post by PurPony » Tue Feb 28, 2012 4:13 am
Hi guys-
need new nc30 swingarm pivot bearings..... where to order them from?? Im in the US.
Also, whats the easiest way to get the old ones out?
thanks
andreasmkr
Bike owned: Honda NC35 RLR Stage III 94'
Re: need swingarm pivot bearings, where?
Post by andreasmkr » Tue Feb 28, 2012 9:27 am
I used these when I lived in the US.
http://www.cheapcycleparts.com/
Parts numbers:
2x 96100-60030-10
2x 91258-hb3-003
1x 91071-mt7-003
That includes all new seals and bearings you need :peace:
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 » Tue Feb 28, 2012 11:38 am
getting them out is a pain in the ass , the ball type bearings come out fairly easy just remove the clip and tap them out with a long drift or driver from the otherside , the roller type bearing is a pain , i used a small cutting disc on a dremmel to carfully cut the case then tapped it out with a long drift from the opposite end.
Deviants AM/PM build
viewtopic.php?f=62&t=27307
Tomzed
Bike owned: Yamaha wr125x and Nc30
Post by Tomzed » Tue Feb 28, 2012 7:48 pm
You can get them from any bearing supplier I have a set in my tool box if you want me to get you the code off them.
Then just ask for the a bearing with the code at your local bearing suppliers
